-   -   strange shifter noise...please help (http://forums.pelicanparts.com/porsche-911-technical-forum/303667-strange-shifter-noise-please-help.html)
thinkfloyd14 09-10-2006 07:17 PM
Recently I replaced all my shifting bushings, replaced transmission oil with Swepco, new ball joints, wevo psj, and finally a WEVO 915 shifter. All worked out ok but recently when its in third gear and i'm accelerating there is a strange grinding or scrathing type noise coming from the shifting area but when i let go of the accelerator pedal it stops.
any ideas
thanks in advance
sammy
Zeke 09-10-2006 07:36 PM
It is possible that the motor/trans mounts are letting your shifter come in contact with the tunnel when torqued up. If this is the case, you might hear the same in 5th, or not. You'd have to get on the power band at some pretty good speeds. Try looking over all your adjustments before becoming too concerned with this noise.
barndoor 06-24-2007 08:04 PM
wevo noise
I have the same problem.Just installed a wevo coupler,no noise,then shifter I am getting a lot of shifter/tunnel/trans noise.Its driving me crazy,I cant hear the engine and its not worth the benefits of the shifter .Any help appreciated..
