Hawks911's Avatar
I give up, what is it???
Any idea of what this item is? Adjacent to the spare, with electrical connections and a clear plastic line that runs up to the smugglers box and down below. Looks like it may be some type of booster pump, maybe for fuel, but only see one line running out of it.
Thanks, and sorry for the newbie question, but couldn't find any reference in Bentley or 101 Projects manuals. (maybe aftermarket)
Old 09-12-2006, 07:35 PM
pjv911's Avatar
Send a message via AIM to pjv911
Air horn pump
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 09-12-2006, 07:38 PM
It could be the compressor for a set of aftermarket air horns.
Todd Sadowsky
slodave's Avatar
My circa 1984 Clifford alarm has one like that. It powers two very loud air horns.
Old 09-12-2006, 07:41 PM
Hawks911's Avatar
Thanks, guys, that makes sense. There are a couple of air horns in the front right fender well. Too late in the day to get on my back, after two long nights pulling a shoddy alarm system off the newly acquired project.
Thanks again.
Mike
Old 09-12-2006, 07:44 PM
slodave's Avatar
The two horns in the right front wheel well are for the horn on the steering wheel.
Old 09-12-2006, 08:08 PM
Flux Capacitor induction module.
Great dramatic lighting too.
1982 911 SC - Grand Prix White Coupe / SOLD
Old 09-12-2006, 08:32 PM
HAL SUX9000... 1.2 jiggawatts goooaranteeed....
Open the hood bay door HAL.....
'72 911T Coupe (9112102748)
'16 Toyota Corolla
'17 Honda HR-V
Old 09-12-2006, 08:40 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Follow that hose and see what it leads to. It looks like it may lead to something that is between the passenger side fender wall and the smugglers box. If its for an aftermarket alarm system, it would be better to remove the entire thing instead of just most of it. After you remove that hose, plug the hole properly.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 09-12-2006, 08:59 PM
Martian communicator device, I mean, loud horn thingey.
Old 09-12-2006, 09:14 PM
Eric Coffey's Avatar
Porsche Exlusiv Option M007: Pneumatic martini shaker.
Old 09-12-2006, 10:31 PM
rnln's Avatar
The circuit board and wiring are there. Look for the ticking digital clock and.. run
Fat butt 911, 1987
Old 09-12-2006, 11:50 PM
ruf-porsche's Avatar
The yellow cap on top of the compressor is for oiling, put a couple of drops now and then into the compressor.
Old 09-13-2006, 12:13 PM
Bandwidth AbUser
Jim Richards's Avatar
electric air freshener
Jim R.
Old 09-13-2006, 12:15 PM
