rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
What are new calipers coated with?
Since they are cast iron, they have to be coated or would rust. I bought a new one last year and it was silver. The remanufactured one I just got is gold— cadmium-plated I believe. What are the new ones coated with?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-13-2006, 03:01 PM
Bill Verburg's Avatar
older calipers were anodized, race Brembos are the same, production are painted
Bill Verburg
Old 09-13-2006, 04:40 PM
rs6er's Avatar
So if I wirebrushed the finish off one of my calipers prior to rebuilding, I'll have to paint it, right?
John
Old 09-13-2006, 04:52 PM
iron will rust w/o a protective coat. aluminum will build up a patina of aluminum oxide.
Yes, it's best to seal them some how unless they are disposable
Bill Verburg
Old 09-13-2006, 05:11 PM
David's Avatar
You can buy caliper paint, probably from Pelican, that's made to handle the heat and fluids.
Old 09-13-2006, 07:42 PM
I just used some engine paint from my local parts store with great sucess. I bought semi-gloss black and taped off what I wasn't spraying and let it rip.
Old 09-13-2006, 08:23 PM
84toy's Avatar
Before disassembly, I screwed in a used brake line and installed a cap on the end. Then I glass beaded the entire caliper, tore them apart, honed the bores and finally put them back together after a good cleaning.. I used caliper paint and it stuck well to the glass beaded finish. They look new.
Caliper paint is designed to be tolerant to amount of heat generated by a brake system.
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 09-13-2006, 09:14 PM
schleg79's Avatar
The caliper paint kits are also really handy if you just want to paint the calipers while they are installed.
The kits come w/a cleaning substance of some sort, as I recall. Also, the paint is intended for use w/included paintbrush (mine had a smooth finish, no runs at all) so there's no taping req'd, etc...
I went w/silver on my previous SC and they looked terrific! Considering gold on my current ride.
78 SC Coupe Silver
79 SC Coupe GP White - sold
Old 09-13-2006, 09:39 PM
