-   -   Is this the meter that shows capacitance and what setting do I use (http://forums.pelicanparts.com/porsche-911-technical-forum/304745-meter-shows-capacitance-what-setting-do-i-use.html)
kekumu 09-16-2006 04:03 PM
Please helphttp://forums.pelicanparts.com/uploa...1158447804.jpg
kekumu 09-16-2006 04:05 PM
OOPS
http://forums.pelicanparts.com/uploa...1158447903.jpg
kekumu 09-16-2006 04:06 PM
haha
http://forums.pelicanparts.com/uploa...1158447969.jpg
kekumu 09-16-2006 04:07 PM
my other son
http://forums.pelicanparts.com/uploa...1158448024.jpg
Early_S_Man 09-16-2006 06:22 PM
Kekumu,
Yes, that meter will measure capacitance on the five green scales, however, you will need to extend the test lead banana plugs [that normally plug into the three sockets at the bottom] by wrapping with solid 20 ga wire to be able to plug into the Cx socket adjacent to the F range labels. Or, you could modify a couple of general purpose clip leads with alligator clips on both ends -- by cutting off one alligator clip, and soldering a 1/2" piece of straight 20 ga bare wire to the wire, then cover all but 3/8" of the solid wire and soldered splice with shrinkwrap tubing. Be careful not to allow the test lead wires to short together outside the Cx socket.
Good luck!
edit:
After looking at the Permatune tech page, the meter would need to measure up to 275 uF, and the meter pictured above doesn't have a range high enough to make such a measurement! It is limited to measurements of 20 uF or less.
