-   -   Green wire source (http://forums.pelicanparts.com/porsche-911-technical-forum/304845-green-wire-source.html)
PhatA55 09-17-2006 11:30 AM
Green wire source
I need to replace my green dizzy>cdi wire because mine doesn't have the 2 pin plug, it goes straight to the cdi. I have the replacement piece for Pelican but it requires a plug. However, my wire has heat damage for about 12" so the replacement is too short. I need a source for the green coaxial wire (or better) so I can build a new harness. Has anyone been able to locate a source?
PhatA55 09-17-2006 05:42 PM
I can't believe no one has ever had to replace this wire!
fredmeister 09-17-2006 07:41 PM
I believe you can buy it
I think you can get it from Pelican or vertex auto. It comes in a 24" length as well, I think it may be the one for the 928 Porsche....do a little calling and ask around.....I honestly don;t remember who I bought mine from. Just remember it is a coax cable so the electrical connectors will have to be fabbed up to make it work properly.
Early_S_Man 09-17-2006 08:21 PM
The easiest and least expensive replacement coax [with PVC jacket] would be RG-174 @ $41.13/100 ft from Allied Electronics and many other sources. The RG-174 coax probably won't last any longer than the factory cable, since neither is rated for the underhood temps of a 911 ... but, when you consider how long the cable lasted on most of these cars, I tend to think most would say good enough! For the price difference ... you could make up spares, keep one in your trunk, and give away or sell a few to SC/Turbo owners!
http://www.alliedelec.com/Search/ProductDetail.asp?SKU=708-9974&SEARCH=&MPN=9174+BK005&DESC=9174+BK005&R=708% 2D9974&sid=450C900012E8617F
RG196 with Teflon jacket and higher temperature rating is 3.7 times the RG174 price from Allied.
http://www.alliedelec.com/catalog/pf.asp?FN=364.pdf
I am not sure where you would get the connector that plugs into the distributor, but there may have been a posting in one of the 'green coax' threads for it ...
The one-piece replacement cable from Permatune is obscenely priced at around $250!!!
PhatA55 09-18-2006 08:05 AM
Thanks guys, that's what I needed.
