PhatA55's Avatar
Green wire source
I need to replace my green dizzy>cdi wire because mine doesn't have the 2 pin plug, it goes straight to the cdi. I have the replacement piece for Pelican but it requires a plug. However, my wire has heat damage for about 12" so the replacement is too short. I need a source for the green coaxial wire (or better) so I can build a new harness. Has anyone been able to locate a source?
--Mark--
1979 RoW 930
1999 BMW Z3
Originally posted by randywebb
It is the people who have some kind of psychological problem and use the car (or some hierarchy they set up involving the cars) to try to elevate their personal sense of self-worth that irks me. I feel sorry for them of course, but they are difficult to put up with.
Old 09-17-2006, 11:30 AM
PhatA55's Avatar
I can't believe no one has ever had to replace this wire!
--Mark--
1979 RoW 930
1999 BMW Z3
Old 09-17-2006, 05:42 PM
Smart quod bastardus
fredmeister's Avatar
I believe you can buy it
I think you can get it from Pelican or vertex auto. It comes in a 24" length as well, I think it may be the one for the 928 Porsche....do a little calling and ask around.....I honestly don;t remember who I bought mine from. Just remember it is a coax cable so the electrical connectors will have to be fabbed up to make it work properly.
Old 09-17-2006, 07:41 PM
Early_S_Man's Avatar
Porsche Crest
The easiest and least expensive replacement coax [with PVC jacket] would be RG-174 @ $41.13/100 ft from Allied Electronics and many other sources. The RG-174 coax probably won't last any longer than the factory cable, since neither is rated for the underhood temps of a 911 ... but, when you consider how long the cable lasted on most of these cars, I tend to think most would say good enough! For the price difference ... you could make up spares, keep one in your trunk, and give away or sell a few to SC/Turbo owners!
http://www.alliedelec.com/Search/ProductDetail.asp?SKU=708-9974&SEARCH=&MPN=9174+BK005&DESC=9174+BK005&R=708%2D9974&sid=450C900012E8617F
RG196 with Teflon jacket and higher temperature rating is 3.7 times the RG174 price from Allied.
http://www.alliedelec.com/catalog/pf.asp?FN=364.pdf
I am not sure where you would get the connector that plugs into the distributor, but there may have been a posting in one of the 'green coax' threads for it ...
The one-piece replacement cable from Permatune is obscenely priced at around $250!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-17-2006, 08:21 PM
PhatA55's Avatar
Thanks guys, that's what I needed.
--Mark--
1979 RoW 930
1999 BMW Z3
Old 09-18-2006, 08:05 AM
