cookster
Guest
Posts: n/a
engine stand
Has anyone used a std engine stand in place of a porche stand during a rebuild ?
Old 06-04-2000, 01:43 PM
mackgoo
Guest
Posts: n/a
Yes I have. It takes a little modifying but works fine.
Old 06-04-2000, 05:54 PM
RarlyL8
Guest
Posts: n/a
Yes, I've got a 930 on one right now. You need to drill holes farther up the arm on two of the attachment legs where they attach to the stand faceplate. If you mount the arms to the rear of the motor and position the stand plate you will see where the holes need to be. Cost me a whopping $35 total.
Old 06-05-2000, 07:16 AM
cmsteed
Guest
Posts: n/a
Yes. I went to the salvage yard and bought the "clutch cowl" (intermediate piece between the motor and transmission) from a wrecked automatic VW beetle for $25. The motor end bolts perfectly onto my 79SC. The "cowl" was drilled and bolted to the mounting studs of a standard motor stand. Total cost of the assembly including stand approx. $65 U.S.
Old 06-05-2000, 03:08 PM
cookster
Guest
Posts: n/a
Thank you for the good news guys.Now I can borrow my buddy's engine stand for little while.
Old 06-05-2000, 04:41 PM
