Bland
unclebilly's Avatar
Fun Lunch...
After backdating my exhaust and a few other odds and ends, I noticed that the oil lines that feed the tencioners and cams were leaking at the rubber to steel junctions.
I decided to get the rubber bits replaced during my lunch hour today at the local hydraulic hose shop so I brought a 12mm, 14mm, and 17mm wrench with me.
I went to Green Line ffirst and pulled off the right side oil line. The guy there was too dumb to do the job for me (and I didn't want to convince him he could do it...) even though this location built the oil lines for another vehicle in the past. I put the line back on the engine and left.
I went down the street to the competition where they were more than willing to do the job for me. I got the guy to take a look before I pulled the line off this time. I puilled off the line, he took it apart and discovered that they didn't have 5/16" high temp hose. They managed to crimp on some 3/8" hose over the ferals and did a really nice job. I got them to fix up both sides which required me to pull the distributor.
When I put it together, I got the dist back in retarded by 1 tooth. I tried to drive away like this but ended up pulling over, yanking out the dist one more time and reindexing it. The car runs great now - I just need to clean up the oily mess I made on the engine. I got back to work 30 minutes late.
Old 09-19-2006, 02:56 PM
Hendog's Avatar
You sure do pack a lunch
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 09-19-2006, 03:27 PM
LakeCleElum's Avatar
Good job, I always used to sneak out of the office and do that kind of stuff "on the clock".....You're a committed employee!
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 09-19-2006, 03:51 PM
