Banned
shim location to tighten fan belt?
Hi I have a 1982 porsche sc and was wondering where the shims were located to tighten the fan belt ? I understand how the shims work, just dont know where they are located. Thanks
Old 09-26-2006, 09:00 AM
dhrcr911s's Avatar
between the pulley halfs and outside the pulley between the nut and the outer pulley half.
SWB 911S 1967 307653S in my fathers garage now
LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon
Old 09-26-2006, 09:05 AM
Don't forget to use all 6 shims provided. The proper number used between pully halves determines desired belt tightness...and the "unused" number of shims are placed between the nut and the outer pulley. This is important so that the nut doesn't bottom out improperly ..and to prevent mechanical damage to the alt shaft and pulleys. Example: if 4 shims are used for the desired belt tighness...use an additional 2 shims under the nut.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-26-2006, 09:09 AM
