95 cab top lock motor problem
My '95 cab passenger side lock motor is still turning after the top is up and the driver side lock motor stops. The gauge cluster has the top warning light on. If I push up on the top on the passenger side when the top is "locked" it does move up while the driver side is locked. When I play with the lock mechanism on the passenger side I can move the cams while I can't on the driver side. These motors were replaced about 2 years ago by Porsche as a recall item.
My question is can I fix this problem or do I have to buy a new motor?
Old 10-01-2006, 04:45 PM
WydRyd's Avatar
Sounds like a replacement is in order. You can typically pick those up for ~$100 on Ebay. They are easy to remove and replace. I've done mine twice, no big deal.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 10-01-2006, 07:39 PM
PRO Motorsports
Tyson Schmidt's Avatar
That clicking sound is the stripped out worm gear in the latch. Both mine are bad.
I already removed all the power top pieces and I'm going to get some roller latches from a late Targa to convert it to manual.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-01-2006, 07:49 PM
