Fan Housing quick question
Quick question 3.2 engine fan and alternator to fan housing.
Secured with 3 studs. Is it also a press fit? I am thinking this is just stuck from corrosion swelling the housing.
Thanks.
Aloha, Rob
89 911 Silver Ann.
Old 09-20-2006, 03:30 AM
After removing the 3 nuts on the back of the housing that hold the alternator in, the alternator should come out. It is a slip fit, but if it was a little tight to start with, the corrosion between it and the housing will make it difficult to remove. REmove the OTHER 3 nuts and remove the air guide from the back of the housing, then -- carefully -- use a rubber hammer to break the corrosion and remove the alternator. You can't just pound away with the hammer -- pick your spots wisely.
Old 09-20-2006, 04:38 AM
Okay thanks that's what I thought. Alt took a crap on me. Pounding does'nt budge it. Will take to work and press it out. Hopefully without damaging the alt.
Aloha, Rob.
89 911 Silver Ann.
Old 09-20-2006, 04:53 AM
This *might* help some--->
http://www.pelicanparts.com/techart...reg_replace.htm
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-20-2006, 08:43 AM
Tapping wouldn't budge it. Took it to a press. Talk about stuck. Scrap one housing. Thanks for the replys.
Aloha, Rob.
89 911 Silver Ann.
Old 09-21-2006, 05:00 AM
I use a rubber mallet and pond the crap out of it if it has not been taken out in a while. If I am taking the alternator out of the housing then the alternator needs to be worked on anyway.
But hey thats just me.....and it works for me with out damaging the alternator....
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 10-01-2006, 07:46 PM
