-   -   3.2 with Webers - Distributor Issue (http://forums.pelicanparts.com/porsche-911-technical-forum/305503-3-2-webers-distributor-issue.html)
Cire 09-21-2006 04:31 AM
Howdy All,
I have recently bought a 87 3.2 and droped it in my car. The car runs great but I think the distributor needs to have the curve set correctly. I currently have a 2.2 distributor in the car running electronic points. Who is the best person to do the recurving? Whats the best distributor to get if I am looking for one off the shelf? Is this even possible?
Thanks for any insight I can get. = )
Eric
81 911 SC 09-21-2006 05:54 AM
Get in touch with the guys at PMO. They will be able to tell you who to go to for re-curving your distributor.
Early_S_Man 09-21-2006 11:12 AM
2.4, 2.7, 3.0, 3.2 distributors fit in a nominal 30.0 mm bore in the case, and the distributor's shank for 2.0 and 2.2 engines is smaller, IIRC 28.0 mm.
911pcars 09-21-2006 11:15 AM
Engine doesn't sound like it is built to stock specs. Before recurving the distributor, I'd put the car on a chassis dyno to find the optimum spark advance for your engine through the rpm/load range. Aim for a few degrees less for real-world driving and octane variables, then send your distributor and the timing advance chart to Steve Weiner to modify.
Sherwood
