Member 911 Anonymous
Okay Fellas,
I got hit by an Idiot stick and used a 6 point Torx star instead of the 12 point star to remove my CV joint bolt from GKN. Tip to tip 56MM (minus head 47MM) X 8MM. For the life of me I can not find a replacement and GKN is absolutely no help at all. Anyone have a source for couple of 12 point star bolts. Moral of the story, do not wrench in the dark, literally at night, can't see shiesse. ![]() TIA, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Yo
Hey man, maybe this is a dumb question, but why not just get another type of bolt in the same size? Does it have to be 12 point star?
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Spiderman
Given the opportunity, I would replace any Torx or triple square bolt/nut I find if a replacement can be obtained. As I hear, they are only used by manufacturers because automated assembly equipment at the assembly plants work better with those fasteners. Later for us, simply a PIA and tool box filling activity. Just got me a 2012 GTI and not looking forward to all those goofy 3x square fasteners.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
gearhead
Jim,
How many do you need? I might have some in my hardware stash.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Diss Member
I think I have some servicable bolts. I'll check the garage in a bit...
But does the 85 915 use the same bolts? I know they changed the flange/bolts somewhere in the run of the 915 Carreras.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Diss Member
"BzzzzzztThankYouForPlaying"
Sorry, mine are 10mm bolts.
There are plenty available from VW suppliers for beetles and the like.
Brakes / Rear Suspension : CV Joints / Axle Boots Bug - Dune Buggy Parts, Sandrail Parts, VW Parts - MooreParts.com I would tend to replace them all with Holo-Krome Allen Socket screws as they will be very well quality controlled. |
Platinum Member
Many of the newer bolts (either ordered by part number, or included in the CV joint kits) use internal hex instead of the internal triple square.
I will PM you now, So Grateful!
![]() Those could work :-) Thanks Chris 7
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-24-2016 at 05:29 PM.. |
Racer
Holo-Krome is the brand I use. I also use 6-point sockets as they are more universal.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
