1977 911 Fuel Line help needed
Now that I have a new fuel pump in, I have found significant leaks (4 pinholes spraying a lot gas) in the fuel line running from the warm-up regulator to the fuel distributor.
Pelican shows lines for 1978 - 80, and 1981 - 83, but none for the 1977. Will the 1978 work? If not, any guidance? |
dm,
First let’s decide which fuel hose. Here is the PET for a ’77 CIS (K-Jetronic). What one is leaking? #72 is the long, complicated one that typically leaks. " "© Dr. Ing. h.c. F. Porsche A.G. Best, Grady |
It is hose #62 in the diagram
Can I use the existing fittings and have one built?
_________________ Dave Miller 1977 911 Targa 2.7 |
Is your line 62 made of black plastic (may have a rubber cover)?
OEM Porsche part number.: 91111050100; Pelican's website indicates it can be ordered for $40.28.
Thanks for the information - it is indeed black plastic with a rubber cover over a portion of the line
