need flywheel identification...
Hello
may someone tell me more on this kind of flywheel
thanks
Old 09-24-2006, 01:01 PM
Grady Clay's Avatar
Philippe,
It looks like a 906 flywheel or replica.
It clearly fits the 6-bolt 2.0 to 2.7 crankshaft. It is for a 215 mm push-type clutch.
You should measure the depth between the pressure plate mounting surface and the friction surface of the flywheel and confirm it will accept a standard 2.0 215 mm clutch. The original 906 is different (shallower) than the 911.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-24-2006, 02:03 PM
Hello M. Clay
thanks for your response !
I have one crank that's 70.4 stroke stamped : C873556
any idea ?
what would be the market price for the flywheel ?
many thanks
Philippe
Old 09-25-2006, 12:46 PM
