-   -   Carrera Guys: Good 12v source in engine bay? (http://forums.pelicanparts.com/porsche-911-technical-forum/306569-carrera-guys-good-12v-source-engine-bay.html)
WydRyd 09-26-2006 10:21 PM
Anyone know of a good stable 12v source (in engine bay) when the engine is cranking / running only?
Looking for a feasible point to power an electric oil scavenge pump, if I decide to go down that route.
I don't want the pump running whenever the ignition is turned to Accessories.
len911 09-27-2006 04:38 AM
If I remember correctly, on the drivers side, behind the back plastic cover with the single wing nut, you can tap into one of the fuses there. I believe there is 3 of them. One is for the aux heater fan in eng compartment, the other is for the rear defroster, and I think the last one is for a Sportomatic... Just use a voltmeter to check for voltage. Lou
WydRyd 09-27-2006 06:18 PM
OK thanks, I'll check it out :)
RickM 09-27-2006 08:24 PM
Merv,
Here's the layout from the owners manual....
http://forums.pelicanparts.com/uploa...1122431230.jpg
http://forums.pelicanparts.com/uploa...1122431253.jpg
