Nine9six's Avatar
Headlight switch connector
The switch that came out of my 87 911 cab, is part numbered: 911.613.029.03. The switch that was sent was numbered: 911.613.029.02. Do any of you fellas happen to know the difference between the two?
I have attached a photo with me touching the extra electrical connector of my switch, which the 911.613.029.02 doesn't have. These two connectors
The reason I ask, is because the switch that came out of my car, has one more electrical connector, and that extra connector accepts two smaller grayish piggybacked wires. Any clues on the difference?
P.S. I plugged in all the connectors from my switch to the, 911.613.029.02 and the switch works just fine. Headlights operate, dash dimmer works fine. I just dont know what this extra connector is for. Any help would be greatly appreciated.
Thanks in advance...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 10-02-2006, 04:15 PM
