Sputterbug
Guest
Posts: n/a
Rough idle culprit?
My car is idling somewhat jerkily, fluctuating maybe 100 RPM between 600-700. Jerkiness aside, that's low, so I set about adjusting the base idle speed to about 800.
I shut off the engine, then jumpered between the two pins on the ignition board socket as explained in the Haynes manual as well as in various archived posts. I restart and the car is purring right along at 800, steady as a rock!
Take away the jumper... back to the old bluster. Adjust the idle faster to compensate, no dice - still rough and the same speed.
This jumper short circuits the throttle positioner, yes? Does this simple evidence point to that part as either dirty or faulty?
Roger
'85 Carrera 3.2 Coupe aka "Sputterbug"
http://www.rogerplacer.net/911/
Old 06-19-2000, 06:41 PM
