RKessel
Guest
Posts: n/a
Trans swap
Is it worth the money to:
a) add a limited-slip differential to a 915 transmission with a moderately modified engine?
b) upgrade to a G-50 with the same set-up?
What is involved with the G-50 swap?
Old 06-19-2000, 03:29 PM
Early_S_Man
Guest
Posts: n/a
I believe the answer to your first question is yes` as are changing both ring & pinion, and possibly some of the 3rd-5th gear ratios, depending on what your intent for the car is!
Second and third, it depends, and about $4500 ... from advertisements in Excellence!
Warren Hall
1973 911S Targa
Old 06-19-2000, 04:47 PM
