Where can I find one
Hi guys,
Well, the 88 911 Carrera I bought from Victory Motors turns out to have a locking lug set on it. Of course there is no wrench anywhere in the car so I need some help.
Below are a couple of close-ups of the nut. The best way to describe it is "round with three flats milled at even spacing. Anyone know who mfg's. these and where I might find a wrench? I've done some internet checking but no luck so far.
Jim T.
87 911 Carrera
Guards Red Coupe
Cat Bypass, SW Chip, 7's & 9's
Old 09-30-2006, 11:11 AM
the shape of the flats and their placement is fairly unique. Contacting Mcgard locks will do no good without a very accurate tracing of the shape, and then seeing if they respond with a few choices. Contact some wheel shops in your area. There is a lock removal kit, which consists of tapered hardened smooth sockets , that they can hammer onto the lock nut, then remove them. If that does not work, find a good TIG weldor that can spot face the end of the lock nut, weld on a bolt and back it off.
There is no way using a chisel ; you would damage the rims
good luck
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 09-30-2006, 11:35 AM
Brother's Avatar
I wonder if one of those gator - 1 size fits all sockets, with the pins inside would work.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 09-30-2006, 11:42 AM
good idea to try if the outer dimension of the socket is not too large
1970 911 Targa "ST"
Old 09-30-2006, 11:49 AM
Paul K's Avatar
Contact the PO?
Good luck...
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 09-30-2006, 11:56 AM
