Less brakes, more gas!
euro911sc's Avatar
Rear T-Bar Length?
Trying to determine if some bars will fit. What are the lengths of the bars for 915's and g-50s? If they are the same then what's the difference between the two/ how can I tell?
best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-27-2006, 12:29 PM
The pre-G50 bar is 18.5" long
Old 09-27-2006, 12:31 PM
Fronts are 611 mm long ( ~ 24") with a 1" spline length at each end.
Rears are 626 mm long ( ~24.6") with a 1" spline length at one end and 0.75" spline length at the other end.
I *believe* the splines are 40 / 44 count on each end for rear 915 bars.....G50's are different.
See here, too--> http://tech.rennlist.com/911/pdf/torsionbars.PDF
The 18.5" dimension is...I believe..the lever-arm length between the centerline of the rear axle and the pivoting centerline of the torsion bar. It's the "lever" length that acts on the torsion bar.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-27-2006, 01:55 PM
swa911's Avatar
I believe length is the same between the G50 torsion bars and the 915's. It's the size of the splines that are different. I know because I just went through this. The OD of the splines for the G-50 are larger than the 915 bars. At least the outer splines are larger. I never stuck the 915 bars into the car to see if the inner splines engaged.
1978 911SC #737 "D" Class Club Racer
Old 09-27-2006, 02:14 PM
The 915 and G50 torsion bars are about the same length.
Early ( 915) rear T-bars have 44 teeth on one end and 40 on the other. Later (G50) bars from '87-89 have 47/46 teeth.
See here for more info--->Ferch Tbar to Spring Rate formula help needed - G50 bars...
- Wil
Wil Ferch
Old 09-28-2006, 09:50 AM
