WydRyd's Avatar
Question Turbo guys - Question about BOV's.
What high HP BOV do you guys recommend for re-circ application? (i.e: allows you to re-circulate charge air back into the intake for silent operation)?
I'm considering this GREDDY Type R unit.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-26-2006, 07:13 PM
pjv911's Avatar
Send a message via AIM to pjv911
Im curios too. Do you need a aftermarket BOV when boost is at 1bar ?
Ive heard that Forge makes an excellent unit. Any other inputs ?
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 09-26-2006, 07:36 PM
WydRyd's Avatar
Kurt, my car is aftermarket turbo'd, so it never had a BOV. For big HP application, a higher flowing BOV is typically recommended to vent reverse pressure pulses before they reach the compressor and cause surging.
I guess the BigHP Supra guys run these Greddy units successfully, so I may just make the jump and get the TypeR. I like the fact that you can recirc air back into the intake for a more stealth application. It has a 2" outlet
Merv
'89 911 Turbo Cab
Old 09-26-2006, 08:01 PM
WydRyd's Avatar
These Billet Aluminium BOV's are only $65 on EBay and are a drop in replacement for the 996TT's, so I'm just wondering if it'd be suitable for a single turbo application running only 1.0-1.3bar max?
Merv
'89 911 Turbo Cab
Old 09-27-2006, 09:16 PM
rsrfan's Avatar
I run a billet forge unit on my 930. Unlike the stock unit, the forge valve contains a piston, oring, and spring whereas the stocker uses a diaphram. The Forge unit may be disassembled and serviced via allen bolts on the top of the valve http://www.stratmosphere.com/forge_valves.htm
The unit in your picture does not appear to allow for such servicing. ( this may or may not be necessary, however, if nonserviceable you may be forced to purchase another unit if it fails)
JP
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 09-28-2006, 08:34 AM
Original Owner
tsuter's Avatar
Blow Off Valves(BOV) blow off air. Diverter Valves (DV) recirculate air. Two different animals for a similar application.
Whichever you use, the main thing is get one with a PISTON. Caps added for emphasis. Tial BOV or Forge or Bailey DV. Want to see a cheapy??? Shove your finger in a 930 stock DV. Scary. Can you spell leaker???
Or course next we'll have peeps say they were designed to leak at idle.....
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 09-28-2006, 08:52 AM
tial is among the best. My only gripe is it vents to atomosphere so you have to listen to it but they work wonderful and very nicely made
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 09-28-2006, 08:54 AM
Me like track days
Craig 930 RS's Avatar
We need a 930 Forum on Pelican.....!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Original Owner
tsuter's Avatar
Ben, You can barely hear the Tial BOV. Comparatively it is very quite. I have to listen for mine to open.
Here is a pic. The Tial BOV is obvious....it cannot recirculate.
No comments on my welding skills please.....
Now, here is one you can hear all the way around the block. Great for attracting attention in your turbocharged Supra.
And lastly the stock plastic 930 DV. Still in its box on my shop. Guess why its not in use.....
tsuter
Thaaaats Right!!
Old 09-28-2006, 09:08 AM
Thad I just hear mine do the chatter some times it makes me think rice and I don't like that. I have the same one as you
Ben
89 944,85.5 944
914-6werkshop.com
Old 09-28-2006, 09:16 AM
Original Owner
tsuter's Avatar
Here is a snap of the Bailey Diverter valve installed in my 1.8T. That's a manual boost controller in front of it.
For your app, I might consider a DV over a BOV since it seems you anticipate EFI in the future. Maybe two DVs
tsuter
Thaaaats Right!!
Old 09-28-2006, 09:20 AM
Original Owner
tsuter's Avatar
That's strange. I get no chatter. Just a nice "hiss" on transitions. Chtter makes me wonder if yours is opening and closing rapidly when it should not. "Searching" if you will. The spring choice will make a difference.
tsuter
Thaaaats Right!!
Old 09-28-2006, 09:22 AM
Does the BOV spring typically match the Wastegate? IF not how is the BOV pressure calculated?
Warren & Ron, may you rest in Peace.
Old 09-28-2006, 10:34 AM
Original Owner
tsuter's Avatar
No...no direct relationship at all.
The BOV opens on differential pressure across the throttle plate.
Example...throttle plate is open...you got anything from vacuum to 20+psi in the manifold based on the turbo, wastegate, boost controller etc. The pressure or vacuum is the same on both sides of the throttle plate so the BOV/DV stays nicely closed as it should with its spring.
Now you lift off throttle to shift. Throttle plate closes momentarily and you have vacuum below it (3-5-10psi) and maybe some level of boost (3-5-10psi) above it. What ever that differential sum is and if its greater than the BOV/DV spring, it opens.
My BOV spring is 11psi but the boost controller is set at 8psi.
Don't relate the two directly. All it takes is boost+ vacuum across the throttle plate greater than 11psi and the BOV will do its thing.
A low spring weight BOV is bad as it may cause the BOV/DV to flutter at idle when the TP is basically closed but you have vacuum below greater than the spring weight.
Spring weight too high and it doesn't open when maybe it should and you lose some turbo speed on gear shift transition.
Clear as mud??
tsuter
Thaaaats Right!!
Old 09-28-2006, 10:56 AM
beepbeep's Avatar
First:
Thing on the picture is not the 930 BOV. 930 didn't have plastic BOV's. They have gigantic cast-aluminium rebuildable BOV with interchangable gaskets. 930 BOV looks like this:
Second: thing on picture looks like 964 Turbo BOV. It works perfectly fine as well. And yes, it is designed to leak slightly at idle. As soon as pressure builds up it tightens. Unfortunately, ricers don't get this and keep trying to run them as open-air BOV's and end up with vacuum leak.
Third: All you buying bling-bling BOV's believing you actually improve something, check this picture:
Thank you for your time,
Old 09-28-2006, 11:49 AM
tobluforu's Avatar
So true about the bling, bling, honk, honk, hiss, hiss or whatever, but saabs use the same type of plastic diverter valves. I run about 19 psi on my viggen and the damn stock plastic valve that you see in this pic. above blew it's top right off at 14 psi (limp home mode). So the expensive ones are great in the sense that they will last forever, are cleanable and some are adjustable. If it was me I would spend a tad more money and get one.
Old 09-28-2006, 11:58 AM
Original Owner
tsuter's Avatar
OK here is the Porsche p/n for the nice plastic DV 993 110 337 50
And I knew some peeps would say it's designed to leak at idle......
It's like WODs vs FODs for you enginerds.... "Works as Designed" vs "Failure of Design".....
That's only one reason its still on the shelf...
tsuter
Thaaaats Right!!
Old 09-28-2006, 12:14 PM
Clear as mud??
Actually a very good explanation, thanks.
My 50mm Tial has the 11# spring and I was planning on a similar (to your) WG spring.
Sounds as if one could determine if the BOV is in the sweet spot by ear.
Old 09-28-2006, 01:50 PM
youngkang's Avatar
How about this?
86' 930 red "Wild @ss Hotrod" Thanks John
Old 09-28-2006, 02:43 PM
WydRyd's Avatar
I was planning to use TWO of those billet aluminium units I depicted above. One before the IC and one just after the IC. Two for extra flow. I'm only planning to run 1.1-1.3bar max, so I think they'll suffice. The TiAL is nice, but too loud. I have one on at the moment and I hate it!
Merv
'89 911 Turbo Cab
Old 09-28-2006, 03:55 PM
