3.6L Oil cooler upgrade Q
I'm upgrading my oil cooler from a standard Carrera fender mount to a front mount Setrab 22 1/2" x 8 1/2" model 1-STD172. Will this be sufficient for track work by itself or should I use it in conjuntion with the Carrera cooler already in place? This is for my 3.6L engine in my SC. Thanks
1980 911SC Targa 3.6L |
I use a single B&B frt oil cooler 5 1/2 X 2 1/4 X 20
It's hard to compare across brands because most of us haven't had more than 1 front mount installed. Rob Fussi aka Muffinman used a B&B FPOR-9400 Front Spoiler Mount Oil Cooler, with a core size of 6" x 3" x 24" this is the next size up from mine. here's a link to his install
I've done mine three of different ways:
Fender-mount Carrera cooler by itself - inadequate for all but the mildest climes. Two fender coolers: http://rennlight.com/howto/cooler/ Fender cooler and bumper cooler: http://rennlight.com/howto/bumper-cooler/ FWIW, the 2nd setup works better.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Nice info! Do you collect your temp data from the oil gauge alone? OR use a thermometer in the tank? Have you verified that the temps are accurate? I noticed that you said you ran the oil line in the top and out the bottom of the center mount cooler. I believe that you can trap air in your cooler (as you noted yourself in your text), by routing in this fashion. Smart racing offers a note in their oiling products which validates. Their catalog specifically says to route oil in the bottom and out the top of such cooler. I would be that you are losing cooling efficiency due to this routing. Doug
1971 RSR - interpretation |
Senior Member
Good thread!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
RETIRED
I run two in tandem.....one in the stock loaction and one in the nose.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
mikez post some pics of how you did this, I need to do this with the impending 3.6 transplant
Jon |
RETIRED
Used conversion metric fittings to -AN and spliced into the original Carrera cooler and a MOCAL cooler for the nose.
Try BAT INC they have a kit.
I have a Carrera cooler with fan in the fender and a B&B cooler in the front like Bill's. I can run my car hard on 100 plus degree days and the temps stay very cool.
Me like track days
Use in conjunction -
I had an SC with a 3.6 Varioram - it is a must.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Thanks guys--I called Chuck at Elephant Racing and he recommended running both as you suggested.
From Chuck's site;
Grand Am/IMSA Data Guy
I ran a single large Mocal for 3 years and was happy with it until I added AIM Data system this year. The Porsche temp gauge ran up to the second white mark, no higher. I was happy.... until Aim showed that the temp actually hit 250F during warm track days in the northeast. I added a 964 cooler in series, in the fender with fairly poor air flow. Top temps are now around 230F and I can live with that.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Me like track days
Yeah, my 3.6 in the SC hit 240 on a regular basis.......and that was with a Carrera cooler with fan + a front mount (with not great flow through, ie rear exit only had 2 inches clearance)
The 930 runs 210, tops........but it has 3 oil coolers - one in each fender + big sucka up front
