Rustproofing
Any recommendations on rustproofing products to spray into closed in panels? I'm doing my pan and eill use POR-15 on the exposed parts, but want to get something into the closed area between the suspension mounts, etc.
Something that can easily be sprayed. Thanks. David Nolen |
You do not have permissi
About halfway down this one shows my version of a WaxOyl application with some rust converter tossed in for luck. I used a deck sprayer, plastic hose, and made the spray tip custom.
Extremly messy though. Not sure of better, more permanent chemicals that will work, nor how to apply them. Pics of my suspension project
Meanwhile other things are still happening. |
