-   -   First De and mechanical failure (http://forums.pelicanparts.com/porsche-911-technical-forum/307185-first-de-mechanical-failure.html)
crashmy911 09-30-2006 10:01 AM
Had a oil line burst right next to the carrara oil cooler. This sent oil all over the front wheel tire and rear wheel tire. We did a 180 and regained control. So I'm in the middle of removing the lines and am having a hard time removing the old lines form the cooler. What should I use to loosen the large nuts. They don't want to budge?
JeremyD 09-30-2006 10:59 AM
PB Blaster - heat - the correct size wrench. Be careful as they are easy to strip.
Jeff Alton 09-30-2006 11:47 AM
When all else fails, use a dremmel tool to cut the nut off. Be carferul not to mar the fittings on the cooler.
Cheers
VaSteve 09-30-2006 06:54 PM
Get a really long cheater pipe. Have someone counter hold and put a little pressure on it. With a big cheater, a little goes a long way.
I'm sure that 180 was scary, epecially your first event.
Here's me spinning...
http://video.google.com/videoplay?docid=8255978021102390938&q=VIR+944
JeremyD 09-30-2006 06:58 PM
leverage is definitely your friend when it comes to oil lines. 24" is about the minimum
Grady Clay 09-30-2006 07:00 PM
OK, the diagnostician has to ask – Why did it fail? That is a very unusual failure, what happened? Are you sure the hose broke and not the cooler?
First, what year, model? Any mods? Was this on the first lap? Cold?
Best,
Grady
crashmy911 10-01-2006 06:55 AM
1978sc. What failed is one of those flexible hoses that connect the hard lines to the cooler. the cooler is marked 87 so that is when the cooler was made. Is it possible that the cooler failed and caused the line to burst. I don't know? So I was just going to replace those two small flexible lines and fill it with oil and see if it works. What would you guys do?
crashmy911 10-14-2006 01:02 PM
okay I got the lines reconnected and found maybe two quarts of oil left in the car. Filled it wirth oil and it started right up seems to be idleing alright.
jester911 10-14-2006 01:05 PM
You might want to take it up to temp and verify the oil is in fact circulating through the cooler.
crashmy911 10-16-2006 01:20 PM
had it out on suday and the oil lines got hot so I know they are working and not leaking any more. brakes feel funny though
masraum 10-16-2006 01:23 PM
It's probably a good idea to replace the brake pads (all 4 wheels) since those on the pass side have probably absorbed some oil.
crashmy911 10-16-2006 01:46 PM
durring the de I had some problems with pulling on my brakes. they were puling to the left. Only when I was comming off the long straights when I was carring speed. Do you think that my oil line could have been spraying alittle when I had the speed way up and was reveing the engine harder. the brakes seemed to work okay at lower speeds. the Pocano's track is very curvy and not fast so You really only had one high speed corner where you braked hard from around a 100 miles an hour.
jester911 10-16-2006 01:49 PM
When is the last time fluid was changed and bled? You might want to verify a caliper isn't sticking as well.
crashmy911 10-16-2006 03:14 PM
changed the fluid the week before the event.
crashmy911 10-16-2006 03:16 PM
Also being that it was my first DE I wasn't getting on the brakes all that hard. Also it rained most of the time so we weren't pushing the cars all that hard. they bleed at this time. It was a three day event so maybe it is possible I needed to bleed them again but I'm new to all this and didn't have the equipment with me to try that.
rdrr 10-16-2006 04:19 PM
Being that it was your first DE I would definitely inspect the calipers. My 89 Carrera's brakes were fine until my first day at the track. One of the calipers began leaking and developed a strong pull to the left.
mb911 10-17-2006 01:06 PM
crashmy911 Your PM box is full I have tried PM;ing you 25 time over the past month and nothing..
Please call or email me directly its the best way
ben@mkexhaust.com
262-364-7426
and to stay on topic this is realivant to your problem
