First De and mechanical failure
Had a oil line burst right next to the carrara oil cooler. This sent oil all over the front wheel tire and rear wheel tire. We did a 180 and regained control. So I'm in the middle of removing the lines and am having a hard time removing the old lines form the cooler. What should I use to loosen the large nuts. They don't want to budge?
MBruns for President
PB Blaster - heat - the correct size wrench. Be careful as they are easy to strip.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
When all else fails, use a dremmel tool to cut the nut off. Be carferul not to mar the fittings on the cooler.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Virginia Rocks!
Get a really long cheater pipe. Have someone counter hold and put a little pressure on it. With a big cheater, a little goes a long way.
I'm sure that 180 was scary, epecially your first event. Here's me spinning... http://video.google.com/videoplay?docid=8255978021102390938&q=VIR+944
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
leverage is definitely your friend when it comes to oil lines. 24" is about the minimum
OK, the diagnostician has to ask – Why did it fail? That is a very unusual failure, what happened? Are you sure the hose broke and not the cooler?
First, what year, model? Any mods? Was this on the first lap? Cold? Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
1978sc. What failed is one of those flexible hoses that connect the hard lines to the cooler. the cooler is marked 87 so that is when the cooler was made. Is it possible that the cooler failed and caused the line to burst. I don't know? So I was just going to replace those two small flexible lines and fill it with oil and see if it works. What would you guys do?
okay I got the lines reconnected and found maybe two quarts of oil left in the car. Filled it wirth oil and it started right up seems to be idleing alright.
Driving member
You might want to take it up to temp and verify the oil is in fact circulating through the cooler.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
had it out on suday and the oil lines got hot so I know they are working and not leaking any more. brakes feel funny though
durring the de I had some problems with pulling on my brakes. they were puling to the left. Only when I was comming off the long straights when I was carring speed. Do you think that my oil line could have been spraying alittle when I had the speed way up and was reveing the engine harder. the brakes seemed to work okay at lower speeds. the Pocano's track is very curvy and not fast so You really only had one high speed corner where you braked hard from around a 100 miles an hour.
Driving member
When is the last time fluid was changed and bled? You might want to verify a caliper isn't sticking as well.
changed the fluid the week before the event.
Also being that it was my first DE I wasn't getting on the brakes all that hard. Also it rained most of the time so we weren't pushing the cars all that hard. they bleed at this time. It was a three day event so maybe it is possible I needed to bleed them again but I'm new to all this and didn't have the equipment with me to try that.
This Way Up
Being that it was your first DE I would definitely inspect the calipers. My 89 Carrera's brakes were fine until my first day at the track. One of the calipers began leaking and developed a strong pull to the left.
crashmy911 Your PM box is full I have tried PM;ing you 25 time over the past month and nothing..
Please call or email me directly its the best way ben@mkexhaust.com 262-364-7426 and to stay on topic this is realivant to your problem
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
