WOLVERINE's Avatar
Brake Calipers
will 1998 boxter brake calipers fit a 77 911S?
and if not what mods will it need to fit.
1977 Porsche 911S (Widebody)
Old 10-06-2006, 11:09 PM
Send a message via AIM to John Z. Goriup
It's not quite a bolt-on mod. but can be readily accomplished with a relatively simple modification to all 4 calipers since the mounting hole spacing on the calipers and the front struts and the trailing arms are not a match.
I sent my calipers to a company in New Jersey that did a very credible and prompt job. Get a hold of Doug at: http://vehiclecraft.com/
You should also swap out your master cylinder to a 21 or 23 millimeter unit to retain acceptable pedal feel. You may have to address some rotor issues as well. VCI can supply all the bits and will talk you through the entire exercise.
It won't be cheap, but a worthwhile improvement like this never is, and you won't believe the difference in feel, stopping distance, fade resistance and brake modulation.
Regards, John
Regardless of what Graucho said, proud to be an R Gruppe member
Old 10-07-2006, 12:12 AM
Bill Verburg's Avatar
Re: Brake Calipers
Yes, they will fit w/ the proper caliper adapters, TRE, VCI probably others sell the parts. You use '84-89 Carrera rotors.
You can get 95% of the benefit at 5% of the cost by just using '84-89 Carrera calipers and rotors on the front. You don't get the bling w/ this setup though.
Bill Verburg
Old 10-07-2006, 04:49 AM
