-   -   engine numbers info? (http://forums.pelicanparts.com/porsche-911-technical-forum/307225-engine-numbers-info.html)
7483cab 09-30-2006 01:10 PM
Does anybody have info on these numbers? 6281244 930.101.104.4R Thanks a lot, have a great day.
Icemaster 09-30-2006 02:39 PM
6280001 and up was the serial run for L series 911 SC produced between 8/77 and 7/78.
Second number is just a part number, probably for the case.
Grady Clay 09-30-2006 02:42 PM
Welcome to the Forum.SmileWavy
You will find a lot of help here.
The Engine number 6281244 Decodes:
6 = 6 cylinder.
2 = 911SC-USA (Type 930/04, 3.0L, 180 hp).
8 = Model year 1978.
1244 = Sequential number.
930.101.104.4R
Is the casting number for the crankcase (not a type number or engine number).
The Type number can be found stamped vertically in the crankcase just to the right and forward of the horizontally stamped Engine number *6281244*.
Best,
Grady
benzyne 10-28-2006 06:01 PM
So if the last 4 digits of my VIN are 1809 and the last 4 digits of my Engine are 1777, did my engine get replaced with an earlier one? There's only a 32 digit difference.
ttweed 10-29-2006 05:55 AM
There is no correlation of engine serial numbers and VIN in Porsche production.
