engine numbers info?
Does anybody have info on these numbers? 6281244 930.101.104.4R Thanks a lot, have a great day.
Old 09-30-2006, 01:10 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
6280001 and up was the serial run for L series 911 SC produced between 8/77 and 7/78.
Second number is just a part number, probably for the case.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 09-30-2006, 02:39 PM
Grady Clay's Avatar
Welcome to the Forum.
You will find a lot of help here.
The Engine number 6281244 Decodes:
6 = 6 cylinder.
2 = 911SC-USA (Type 930/04, 3.0L, 180 hp).
8 = Model year 1978.
1244 = Sequential number.
930.101.104.4R
Is the casting number for the crankcase (not a type number or engine number).
The Type number can be found stamped vertically in the crankcase just to the right and forward of the horizontally stamped Engine number *6281244*.
Best,
Grady
Old 09-30-2006, 02:42 PM
Drivin' Miss Daisy
benzyne's Avatar
So if the last 4 digits of my VIN are 1809 and the last 4 digits of my Engine are 1777, did my engine get replaced with an earlier one? There's only a 32 digit difference.
58 VW Split Window Bus - Porsche Powered
78 911SC Turbo Look - Megasquirt II, EDIS, 964 intake
92 964 Turbo
Old 10-28-2006, 06:01 PM
ttweed's Avatar
There is no correlation of engine serial numbers and VIN in Porsche production.
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 10-29-2006, 05:55 AM
