+ lurking - contributing
check your Winshield seal
Walking the rows of beautiful Porsches at the PCA corral at the Petit Le Mans, I noticed a common characteristic of most 74-89 911/930s there. The upper corners of the winshield seal is not covering the glass recess thoroughly. A small gap is visible and looks to be an invitation for water intrusion. My 87 930 has this problem as well. I have read threads about replacement with OEM seals only, and the troubles getting correct repositioning.
It may be time for me to begin this tricky task...
Go out and look closely at your seal, what do you find?
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 10-01-2006, 06:00 PM
Eric-325I's Avatar
Re: check your Winshield seal
Exactly what you describe, on the driver's side. It's on my winter project list
Eric
'79 SC Silver over Black... Sold
Old 10-01-2006, 06:04 PM
Kraftwerk's Avatar
If it is raining, I find a leak!
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 10-01-2006, 08:15 PM
I was cleaning my '87 this evening and noticed the samething. There is no evidence that my windshield has ever been out of the car.
’87 Venetian Blue Coupe
Old 10-01-2006, 08:43 PM
ianc's Avatar
Rubber shrinks and cracks with age. Even Porsche rubber,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-01-2006, 09:15 PM
minoclan's Avatar
I caught mine after a DE two weeks ago. The seal is backordered from Porsche. I think I should have it this week.
2007 GT3 Red, 2008 Cayman S Track Car, 1970 911T Tangerine, 2019 AMG E53 4, 2020 S450 2019 F350 King Ranch
R Gruppe Member #626
Old 10-02-2006, 02:07 AM
MAGA
Tim Hancock's Avatar
Mine is the same even though I spent a lot of time trying to avoid it while installing my new seal. I found I could squeeze in a piece of old foam rubber trim into the gap then massage it around enough to keep the lip held up to eliminate the visual gap. Best to probably inject some sealant in there also to actually seal it up better if the car is to sit out in the weather much. I think this problem varies from car to car.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 10-02-2006, 04:50 AM
I inject 3M Window Weld, using one of those coarse plastic glue syringes you can get at a hardware store.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-02-2006, 04:56 AM
Counterclockwise?
Originally posted by ianc
Porsche rubber,
ianc
It's true.
Put a Porsche logo on anything and we'll buy it.
Rod
1986 Carrera
2001 996TT
Old 10-02-2006, 06:49 AM
Ken911's Avatar
my 85 is that way and the bottom corner is real bad inside and out you can see daylight. started getting wind moises about a month ago looked around and found the gap.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 10-02-2006, 07:00 AM
Ken911's Avatar
my 85 is that way and the bottom corner is real bad inside and out you can see daylight. started getting wind noises about a month ago looked around and found the gap.
2019 Silverado 6.2L
I replaced mine and still have a problem
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 10-02-2006, 11:15 AM
From the responses so far, I gather that a new seal still might show corner gaps. Make sure you get an OEM German seal! I also read other posts that it is not a good idea to inject sealants in the channel.
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 10-02-2006, 03:02 PM
My '66 is stripped down now for paint. As soon as it gets out of the booth, it gets a new headliner, then to the glass shop. The glass guy is very experienced, and insists that he will use sealant when the new (OEM) gasket goes in. The front is covered under my insurance--new gasket with new windshield--and I'm happily paying him $60 to reinstall and seal up the rear window at the same time. The shop guarantees that the windows will not leak for the life of the car! I haven't told him I've owned this car for 34 years and plan to drive it for another 34! May be an expensive guarantee for him...
Adam912.out.
Old 10-02-2006, 05:42 PM
Hawkney911's Avatar
you can push it out with your pinky on the list of things to do. right now shes not alowed in the rain.
--Dan
-=1978 911sc targa=-
-=1980 911sc widebody conv=-
-=2009 Carrera =-
Old 10-02-2006, 07:32 PM
Is it hard to replace the seal??
Old 10-03-2006, 04:45 AM
Install425's Avatar
I had the windsheild replaced with factory seal and I have same problem on drivers side upper corner.It leaks down onto kick panel.
Rob,
88 911 Turbo
Old 10-03-2006, 05:40 AM
Same OEM factory seal here on my 67 with the same problems. I installed this one last spring and spent considerable time getting it perfectly centered and still have about a 1-2mm gap on both upper corner's.. very frustrating!!
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 10-03-2006, 07:37 AM
vizail's Avatar
The seal in not the problem . In a long conversation a fellow mechanic explained that with the years the press that makes that part produced a diffect . In other words ..the mold wore off and increased the zise of the frame.
In warm weather the seal and the frame expands. but with the change of weather it shrinks.
The side that holds the glas start falling towards the interior of the car and the part of the the seal that holds to the metal start to separate.
You can fix it with a new seal "but" use a 3mm sealer glue generously when instaling
Vic
Old 10-03-2006, 08:38 AM
pmajka's Avatar
same thing, but no leak
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 10-03-2006, 04:44 PM
