Clock / GPS Mod, suggestions or opinions?
I thought it might be a nice mod to have an in-dash GPS in my 85 Carrera (I like a nice mix of hi-tech and low-tech). So here's my idea, Tuck a Garmin i# GPS unit inside a VDO guage and plug it into the clock position on the dash. Nice upgrade, no permanent damage to the car.
There's already a 12v powersupply for the clock, and I can use that to power the GPS. Since the built in antenna will be obscured by the dash, I can run an external antenna from under the dash and place it somewhere unobtrusive. The Garmin is really tiny, much smaller than the clock, but it looks like it will have to be taken out of its case. Between the donor GPS ($200 eBay) and the rest of the goods, I think I can come in under $300. Any thoughts, comments, ideas are appreciated. Here's the stock view.
Here's a photoshop illustration of an optimal install
And the donor unit:
Ken Justice 1985 Carrera (Ruby II) 1973.5 911T CIS (Ruby, gone but not forgotten) 2004 Buell Lightning (aka Elbow-Crusher, crashed) |
Looks like a very clever idea. Is there room for the unmodified orignal Garmin case inside the clock housing? If not, it looks like fabricating a new faceplate that would adequately locate and support the scroll wheel might be a challenge. If you take the Garmin case apart, you're making a $300 bet on your fabrication skills.
I say go for it, great idea...
Eric
'79 SC Silver over Black... Sold |
It looks like the corners on the Garmin are going to have to be ground down, but the sides and top/bottom will fit inside the clock tube. I want to keep a 100% stok look otherwise I would just have it peeking out of the opening (no mod needed for that just a mounting bracket) with no clock bezel.
Please post pics when you're done; this will be cool if it works!
coolcavaracing.com
Cool, post pics when you are done. I like the idea....
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
H-ll of a lot more useful than a clock but must look OEM to be successful. Besides, your radio probably tells the time.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Great idea. Be sure and take some progress pics - make that many progress pics.
'87 911 Targa - FOR SALE - PM if interested |
cool idea.
subscribed to thread
-Vinny 1983 911SC |
abit off center
with weather would really be koo!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Back in New England!
With an XM satellite subscription you can add traffic and weather to certain Garmin GPS units and use the XM antenna for you receiver. Neat, but the Garmin unit runs about double what hatpix has already purchased.
Great idea! -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
You might try running the unit inside the hole without going the whole nine yards to see if your signal strength is going to be sufficient. Drive around and see if you lose the signal often.
These things were designed I think to be mounted near a windshield not under/in the dash...Could be wrong though and won't be the first or last time on that one........
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) Last edited by madmmac; 10-03-2006 at 02:25 PM.. |
FWIW, I know some antennas (external) are made to be mounted under the dash. You may try to locate one for your garmin project just to keep the entire thing concealed away.
GPS is going to require that you have clear antenna line-of-site for it to work. You won't be able to get away with mounting it under the dash as you would a radio antenna. The GPS signal is way to fragile to work with a concealed antenna.
I know they make them. It is just a matter of whether there is such an external antenna for a garmin unit of that make.
I think the under/over dash antenna dilemma will play itself out when I actually get to the install stage. If it works under the dash, all the better, if not, I may try to hide it behind the rear view mirror (assuming it doesn't require a horizontal orientation for proper use).
I would argue that the RB1 Jeep Cherokee GPS antenna isn't really installed "under the dash" but rather above all the sheet metal, wiring, and other electronics that make up the dash. The shelf gives you a place to mount the antenna above all those potential interferers on that shelf under the plastic fascia that covers the dash components. In addition it looks as if the RB1 system uses sensors not unlike an aircraft Inertial Navigation System to augment the positioning. The scenario would be different if you mounted it under the dash of your Porsche. I'd be willing to wager a beer or two that you would never "acquire" the necessary satellites for the system to work if you place it under the dash somewhere. External GPS antennas are readily available from the aftermarket for a nominal ($20-$50) cost. Most are pretty small at about 1-1.5" square and can be easily "concealed" out in the open without becoming an eyesore on the dash. To get a consistent GPS signal they will need a clear view of the sky. They do not necessarily need to be mounted in the horizontal plane to function properly. If you mounted it on the back of the rear-view mirror you will have some signal degradation but not enough to be noticed.
Hey, the Porsche experience is all about the journey, not the destination. Keep the clock, use the suction cups. It stays portable that way.
YMMV
Mark '88 Carrera GPW Sunroof Coupe '82 SC Targa (RIP) |
Automotive Monomaniac
I have run GPS in my 930 (a suction-mounted Garmin unit). I like your idea, but the placement is poor for visibility reasons (driver, not just acquiring satellites!). It will take you far too long to focus your eyes down there (behind the wheel) and then back to the road surface.
Again, great idea... just a bad place for the screen. Oh, an external antennae will work just fine sitting on your dash - it has to have a CLEAR VIEW of the sky (it cannot go through even a sheet of paper).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Motor, this is ridiculous. Whatever man, I have seen the pics and I installed the unit in my Wrangler. It worked. Not a WJ as you have supplied pics to but similar install. It was just a suggestion.
I have been involved with gps since way before Selective Availability was turned off and I even have the oldest active Geocache in Louisiana. So I know where you are coming from with traditional thinking. I could pick apart: "clear antenna line-of-site" but frankly, I don't care that much. I give you the final word. Hatpix - either way, great idea and a very clever use of space. I can't wait to see your finished product. ...and here is a bump for your great idea
