rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
AC, Console Delete; Voltmeter Add; Switches Solution
Several years ago I replaced my hazard light on the dash with a voltmeter. I rerouted the hazard light switch to the side of the console.
Recently I deleted my console and AC except for the fan. My problem was now I needed a place to put the hazard light and AC fan switch. I made a bracket out of aluminum, painted it black, and mounted it to the bottom of the ashtray with sheet metal screws.
Here are the results though I may repaint it with a pebbly finish or cover it with vinyl:
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 10-03-2006, 11:26 AM
Great work John!
'79 SC
Old 10-03-2006, 11:48 AM
