Cimate controls wire
Hello,
I am installing the correct climate controls for my '86 Carrera. I'm not exactly sure where the white wire is to be inserted after it goes through the hole in the firewall. Can anyone give me a detailed description where and how this wire is inserted for the air conditioning control.
"Charlie don't surf!"
Old 10-02-2009, 07:15 PM
crustychief's Avatar
It is the temp sensor for the evaporator in the smugglers box. Be careful with it because it is a capillary tube. it should have a copper shroud around it and it goes in between the finns in the evap.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-02-2009, 09:14 PM
Sorry I do not have a pic. Mthomas58 had a picture on his A/C install thread IIRC.
Old 10-02-2009, 09:16 PM
Throw it on the ground!
Here is a picture showing where the white wire (capillary tube) gets inserted in the evaporator box - just to the left of the bronze bracket lower center of pic - look for the small red box outlining the insertion point.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 10-03-2009, 07:36 PM
Mark,
It looks like I have a different a/c set up in my 911 as you can see in this picture. I also have a silver box with fins in it up in the top left corner. I can't seem to find where the capillary tube is inserted in mine. Also, does the capillary tube simply get fished in between the fins that are located at the firewall leading to the smuggler's box? Any input would be appreciated.
Old 10-08-2009, 08:12 PM
chocolatelab's Avatar
I just took my evap out last night.
the wire ran thru the hole in the passenger in into the fins of the evap cooler
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 10-08-2009, 08:28 PM
Originally Posted by vancouver86/911 View Post
Mark,
Scott, I don't recognize that set up. You might try sending a PM to Jim Sims or Kuehl (Charlie Griffiths) who are probably familiar with the evaporator box you have.
Mark
Mark
1987 911 Coupe
Old 10-10-2009, 02:28 PM
