Bill is Dead.
2.4 - any good?
I've heard that the 3.0 is "bulletproof" and that the 2.7 is a "timebomb".
My personal experience has only been with a 3.0, and I find it durable and peppy. Anyway, I'm looking at rebuilding another car (discussed in various other threads) and was wondering what people think of their 2.4L engines.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Bye, Bye.
The 2.4 comes in three + versions; T, E, and S. Which motor are you asking about? My research and limited experiernce has made me believe that a 2.4T motor should last somewhere close to a 3.0.
Elvis has left the building. |
2.4S MFI is a great motor (even better with 2.2S hi-comp pistons)!
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
My 2.4 in my 1973.5T has been excellent. For one thing the 2.4 has been known as an engine that will never "overheat". I can attest for that in southern climate with th e AC blasting. My engine was totally rebuilt with new pistons (left "T") and updates like the oil fed tensioners. The 2.4 is very responsive and I have heard as well that its comparable with the 3.0 for longevity. Of course a 3.0 in my 73.5T body would be like having a turbo!!
Bob 73.5T |
Bye, Bye.
Is this true?
user & abuser
yes it the actualy sence of advertised outputs.
however there ia noticable torque differance, and the 3L of course has much more potential, as the reason its output is less, is ude to emissions. Poor header design, emmission friendly(no hp) CIS, retarded timing.... switch to carbs with SSI's and the 3L is alot more engine then th 2.4S.
vini vidi vici |
Nominally, a 2,4 S has 190 HP. A 3,0 SC has 180.
Very, very different engines and driving characteristics.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Warren Hall Student
The 2.4S is only more powerful when wound above 5500 RPM. The 3.0 is more powerful from 0 to 5500RPM.
In otherwords it takes a long straightaway for the 2.4S to catch up and pass the car with the 3.0.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
The 2.4 or 2.7 can easily be built to give "bulletproof" reliability. Of course, it's not going to happen if you go 10.5:1 compression, no twin plug, no front mount oil cooler, RSR Sprint cams, etc. A mild T, E, or even S rebuild w/ proper upgrades to a 7R (some 2.4's are 5R) case can give great power and reliability. Don't overheat the engine or over rev it, use good oil and filter and they last a long time.
The 2.7 is a fine motor w/ proper cooling and no thermal reactors. Much of the bad rep. comes from thermal reactor cars that had no front oil cooler and the AC probably blasting in 95 degree traffic. A recipe for the mag case to pull studs. No one complains about a 2.7RS or 2.8S/RSR motor! |
Bandwidth AbUser
My 2.4E was a great engine, good torque and adequate HP. My 2.7RS engine rocks.
Jim R. |
I agree 100%. The 2.4 in my 73.5 T felt as good as my 3.0 SC unit, peakier even, and it was a T ! And never got hot - without a secondary cooler to boot ! It's been an excellent engine in my opinion. |
Dan in Pasadena '76 911S Sahara Beige/Cork |
Bill is Dead.
The 2.7 reminds me of the old AMF engines. Everyone says they "mark their territory" by leaking oil constantly.... but I found that once it was rebuilt properly, there were no more leaks and it ran well.
Similarly, from the sound of it, a 2.7 if properly built should be undeserving of their reputation.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. Last edited by cashflyer; 10-05-2006 at 03:05 PM.. |
Re: 2.4 - any good?
That said, not much difference in building cost between a 2.4S and a 2.7RS engine, especially if starting from scratch.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
