checking timing
can anyone tell me how to check and adjust the timing on a 79 3.0 911 thanks Bill
There is a sticker in my car, on the inside of the deck lid, that give the timing specs for my car. Yours may be different.
When I remove the vacuum hose, the idle rises, so then I have to adjust the idle back down to 900 to check timing. When I'm done and I reattach the vacuum hose, idle drops and I then have to increase the idle back to 900. In the meantime, with idle at 900 and vacuum hose disconnected, timing should be at 5 degrees BTDC. Your car's spec may be different. ------------------ '83 SC |
| All times are GMT -8. The time now is 06:26 AM. |
