por73911's Avatar
Lsi?
How can you visually tell that you have Limited Slip?
Paul Williams
Old 10-07-2006, 08:36 AM
Paul:
The easiest and best way to tell whether you have an LSD in your car is by lifting the rear wheels clear of the ground and putting the transmission in neutral.
Rotate a rear wheel while observing the opposite side one. If they rotate the same direction, you have an LSD. If they rotate in opposite directions, you have an open differential.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-07-2006, 08:50 AM
por73911's Avatar
Thanks Steve
Paul Williams
Old 10-07-2006, 08:55 AM
