oit tank differences 83 to 86 turbo??
Is there any differences between to oil tank on an 83 SC to a 86 turbo 911??? (Actually the car is a NA car but is factory widebody with everything turbo but the engine including suspension, brakes, wheels, ect. so its the same as factory turbo in every way). Thanks, Mark
The 930 oil tank has an additional fitting for the turbocharger oiling. It is the same as a Sporto tank. Probably cheaper to just buy a tank as have one modified.
Good luck. That is one of the simpler things you will ahve to address. John Rice |
John, Im cutting up the 86 widebody car that was factory turbo everything but the engine. I didnt know if there would be any atvantage to changing out my oil tank that is currently in the 83 SC?? Newer, lighter, more capacity, ect??? Should I change it or just keep the one already in the car??? Im going with a NA 3.6 engine non turbo engine. Your thoughts anyone else?? Grazzi!!
| All times are GMT -8. The time now is 01:48 AM. |
