Banned
oit tank differences 83 to 86 turbo??
Is there any differences between to oil tank on an 83 SC to a 86 turbo 911??? (Actually the car is a NA car but is factory widebody with everything turbo but the engine including suspension, brakes, wheels, ect. so its the same as factory turbo in every way). Thanks, Mark
Old 10-07-2006, 12:37 PM
The 930 oil tank has an additional fitting for the turbocharger oiling. It is the same as a Sporto tank. Probably cheaper to just buy a tank as have one modified.
Good luck. That is one of the simpler things you will ahve to address.
John Rice
Old 10-13-2006, 01:38 PM
Banned
John, Im cutting up the 86 widebody car that was factory turbo everything but the engine. I didnt know if there would be any atvantage to changing out my oil tank that is currently in the 83 SC?? Newer, lighter, more capacity, ect??? Should I change it or just keep the one already in the car??? Im going with a NA 3.6 engine non turbo engine. Your thoughts anyone else?? Grazzi!!
Old 10-13-2006, 02:31 PM
