This Way Up
rdrr's Avatar
What do I do with this hose?
I found this hose in my engine compartment after I removed my a/c. I traced it back to the activated carbon container and believe that it would normally be connected to the airbox. I have a K&N cone filter, so what should I do with this hose?
Old 10-07-2006, 12:20 AM
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
send it to Foley's office...he's going to be VERY lonely...
Greg....PCA, 356 Registry, 912 Registry
1977 911S Targa with 3.2...1960 T-5 coupe
1968 912 coupe, that's 32 P-cars, so far...
1990 Chevy 4x4 2500 pickup (with 255K & still rockin')
Old 10-07-2006, 02:58 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Is that the "oil breather hose" coming off of your oil tank and then going into that active carbon filter?
Where does that white hose go to after coming of that filter too?
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-07-2006, 07:04 AM
I Have a K&N filter also, I made a "kind of" maniflod using a 1" rubber hose to connect the oil breather, charcoil canister hose, cold start valve vacum hose and turbo oil cooler reservoir breather hose. Then, drilled a 1" hole on the air filter holder, installed a rubber bonnet and inserted the " 1" rubber hose manifold" through it. 30K miles ago and works like a charm.
However, you can just leave it alone hanging in there...
What did you do with the oil breather and cold start vacum hoses?
Old 10-07-2006, 07:59 AM
This Way Up
rdrr's Avatar
The PO installed the K&N. I'll check where the other hoses go and post again.
Old 10-07-2006, 01:07 PM
This Way Up
rdrr's Avatar
Here's a couple more pics. The breather hose terminates behind the throttle body (pic 1). I followed the white braided hose to the rear left of the engine compartment but could not find exactly where it ended - I didn't want to mess too much with the lines back there.
Any thoughts?
Old 10-08-2006, 01:35 AM
I think everybody but Darkbeer is wrong.
Old 10-08-2006, 07:21 AM
