-   -   Confirm Hall Sensor is trigger in SC & signal description? (http://forums.pelicanparts.com/porsche-911-technical-forum/308420-confirm-hall-sensor-trigger-sc-signal-description.html)
JohnJL 10-07-2006 06:05 PM
I am having a bear of a time tracking down some ignition noise. I am going back to square 1 to be sure I haven't made any silly assumptions or mistakes.
I was positive my stock 1982 or 83 distributor uses a Hall sensor. It had the infameous "green wire" which was cracked and corroded, which I've replaced with sheilded wire and new connectors. However I am not getting the expected results.
Also, Megasquirt stated most Hall sensors have 3 wires, causing me further concern.
Is it actually a VR sensor? Can anyone describe the actual signal? Is it - and + or just 0 and +? Or something else?
thanks all
Steve@Rennsport 10-07-2006 07:09 PM
John:
SC's do not use Hall sensors for ignition triggering, its a simple magnetic pickup; + and -.
JohnJL 10-08-2006 06:39 AM
Well that would be my problem. Thanks steve. Again.
