Best Dino Oil for '87??
I am using Shell Rotella 5W-40, type III, but have heard that the high detergent content of diesel oils can actually reduce compression? Other than diesel oils what is a good 20W-50? GTX, Havoline, Chevron, Valvoline, etc?
Old 10-08-2006, 08:41 AM
plymouthcolt's Avatar
I believe it is formulated with special detergents for use in diesels which have a high sulfur content in the fuel.
I heard it has a higher zinc content which is bad for O2 sensors and plugs.
I use Formula Shell 20w-50 in summer and 10w-40 in winter.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 10-08-2006, 11:41 AM
[i]I heard it has a higher zinc content which is bad for O2 sensors and plugs [/B]
FWIW, Zinc does NOT harm plugs or oxysensors. Zinc CAN degrade the latest types of cats.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-08-2006, 11:58 AM
However the phosphorus (which is with the zinc in the oil) can send oxygen sensors to an early grave if the engine is burning/blowing excessive oil out the exhaust past the oxygen sensor.
Old 10-08-2006, 09:28 PM
Jim:
If an engine is consuming that quantity of oil, then I'd submit that one has far bigger issues to deal with than a shortlived oxysensor.
A good quality (Bosch OEM) oxysensor lasts a good long time (30K to 60K) and is amazingly tolerant of less-than-ideal operating conditions. As long as one doesn't contaminate it with excess antiseize on installation, silicone compounds, overfilled oil tanks, and leaded fuels, they work just fine.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-08-2006, 10:00 PM
anthony's Avatar
Recent thread that is applicable:
An Oil Additive that is worth using
-Anthony Siino
1981 911SC
1974 914 2.0L
