Grappler
supercharged 3.2 conversion
I finally got the car just about where I want it. (for now) But I thought I would post a few pics for everyone. 76 tub, with paxton supercharged 3.2, 915 limited slip, big suspension and big brakes. All the usual mods one would expect to go along with a blown 3.2 in an early tub.
C'mon! You can't talk like that and not show any engine pics... GEEZ, what are you thinking?
Bill 997.2 |
Wow. That car is sweet! Deep down I have always preferred the post '73 look to the early look, everything else being equal. They're just more modern looking, imo. Great job. What kind of horsepower is that engine making? |
Wow! More pics! More engine info!
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Please share the details on the supercharger conversion. Who made it? Boost level? HP? I am considering the same setup.
86 Carrera 70 914-6 |
one of gods prototypes
![]() engine pics are required now.......meaning now
Brought to you by Carl's Jr. |
Driving member
Yep this thread is meaningless without engine pics. This is like a stripper walking in fully clothed and telling us, you oughta see what is under the overcoat.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Bring it Bill... you big teaser.
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
Back in New England!
Engine pics are a must.
Supercharger specs are a must. Or as the Germans call it "Kompressor". Thanks, Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Patton No Porsche at the moment but give me 6 months and then...... |
Grappler
Sorry guys. ok here it is without all the fancy crome plated brackets. It is very close to the SOK setup. I used the same chip and fuel pressure regultor, but I had to fabricate all of the mounting brackets and ducting. I've been in contact with the owner of SOK (superchargers of knoxville) who pretty much walked me through the process. They stopped making this kit quite some time ago. It puts out between 7-8 lbs of boost, and according to SOK will boost a bone stock 3.2 to 345 hp. Ive never dynoed it but this blower on any slightly modifyed 3.2 in an early car will beat most things on the road. The power curve is very linear, with zero lag. Another advantage to the paxton is that it has a self contained oil system, and requires no intercooler. Bascially, it pulls like theres a big block chevy engine back there, but under normal driving conditions you cant even tell its there. |
Nice execution. I've been thinking of doing something similar using a supercharger from a 3.8L Ford T-bird Supercoupe. Guys have been putting them on 4.0 Rangers and getting 75+ HP at the rear wheels. Do you get any belt slippage with the V-belt? Also that looks like a modified Ford belt tensioner, am I right?
No intercooler required? They're never required but do help build power and decrease chances for detontation on a stock higher compression engine. I'd consider one if I were you.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Grappler
The tensioner on the left hand side is off any 80s or 90s mustang. However I have it mounted solid directly to the motor mount. Its only purpose is to drop the belt straight down from the blower. The tensioner on the right is the one used for belt adjustment. I think it came off an early (mid 70s) Chevy. But I'm sure there are several ways one could go about getting the drive set-up. As far as I can tell there is no slippage whatsoever. I just check the belt and the fluid periodically. According to SOK the Whipple supercharger uses an intercooler, but all of the kits they sold since the 90s did not use one for the Paxton. Apparently they felt the Paxton did not generate enough heat and adding one would yield very limited improvement. But being that I am not a professional in this area I am not really qualified to give a definitive answer. I hope this helps.
Very interesting setup! It's giving me ideas, but I have the RoW 3.2 with higher compression. Any ideas if it'll work on that motor?
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Awsome!
That's exactly what I've been looking for. Any idea what the guys in Knoxville charge? Do they have a DIY kit? Thanks,
Any idea if that supercharger would fit under a stock decklid?
'74 Euro Carrera * '64 356SC Coupe |
Can you share with us your steps for the setup, what part you used for what, where to get the tubing, etc. Many of us dream of 345 HP on a DIY project.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" Last edited by DonMo; 10-10-2006 at 12:23 PM.. |
Rod, PM sent regarding cost, parts. Thanks
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
Juicersr,
I'd like that information as well. I would very much appreciate it.
Throw me into that same info group.
Awesome set-up. I spoke to TRECUP about that exact setup during our "pelican dinner" at Tarpys. Thanks, Matt
