cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
What Transmission do I have
The car is a 73 911 E
The numbers on the bottom of the transmissions are 7323167.
The shift pattern is a regular 5 speed H. 1st is up and left. Reverse is down to the right.
Chris
Old 10-12-2006, 01:01 PM
GrantG's Avatar
That's a 915 gearbox. Versions of the 915 were used from MY1972 to MY1986 and the gear pattern you described is consistent with a 915.
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 10-12-2006, 01:08 PM
Bill Verburg's Avatar
you have a 915/02 5 spd, magnesium case
732 means its a '72 trans but both '72 and '73 used the same trans
Bill Verburg
Old 10-12-2006, 01:09 PM
GrantG's Avatar
Thanks Bill - also of note is that your gearbox will have the 7:31 ring and pinion (lower gearing ratio than later 8:31 which means you have the right one for better acceleration with a 2.4E motor).
Old 10-12-2006, 01:12 PM
cmcfaul's Avatar
Great, thanks guys
Chris
Old 10-13-2006, 04:42 AM
