-   -   Installing 86 dash in an SC??? Help, please? (http://forums.pelicanparts.com/porsche-911-technical-forum/309607-installing-86-dash-sc-help-please.html)
markmaunz 10-14-2006 07:26 AM
There was a post back about a yr ago about putting a 86 or newer dash into a SC or older car and I cant find it. Any one here done it or know of someone who has?? I could sure use some advice. lol. Mark
Jim Smolka 10-14-2006 07:40 AM
The dash was changed in 1986. The vents are bigger in the center and on the sides. You will need those vent pieces as well. (I have some of them).
FenderGuy 10-14-2006 08:19 AM
I also plan on doing this swap ...
markmaunz 10-14-2006 01:19 PM
Help!!!
KevinP73 10-14-2006 01:26 PM
except for the larger center vent everything is pretty straight forward. Remove the old one, clearence center vent, install new, sit back.admire work, drink a beer.
MattAlpha 10-14-2006 02:35 PM
Another small thing; well depending on how you look at it. You most likely will have to remove you windshield and dash pad as well to do the swap.
-Matt
markmaunz 10-15-2006 05:20 PM
Kevin, and Matt or Jim, Have you guys done this dash swap?? Also, I want to use the dash part that is directly under the top dash pad too. Anything to know there about removal or install?
Jim, Ive got a donor car for all metal and dsh parts. Thanks, Mark
