Banned
Installing 86 dash in an SC??? Help, please?
There was a post back about a yr ago about putting a 86 or newer dash into a SC or older car and I cant find it. Any one here done it or know of someone who has?? I could sure use some advice. lol. Mark
Old 10-14-2006, 07:26 AM
Jim Smolka's Avatar
The dash was changed in 1986. The vents are bigger in the center and on the sides. You will need those vent pieces as well. (I have some of them).
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 10-14-2006, 07:40 AM
FenderGuy's Avatar
I also plan on doing this swap ...
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 10-14-2006, 08:19 AM
Banned
Help!!!
Old 10-14-2006, 01:19 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
except for the larger center vent everything is pretty straight forward. Remove the old one, clearence center vent, install new, sit back.admire work, drink a beer.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 10-14-2006, 01:26 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Another small thing; well depending on how you look at it. You most likely will have to remove you windshield and dash pad as well to do the swap.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-14-2006, 02:35 PM
Banned
Kevin, and Matt or Jim, Have you guys done this dash swap?? Also, I want to use the dash part that is directly under the top dash pad too. Anything to know there about removal or install?
Jim, Ive got a donor car for all metal and dsh parts. Thanks, Mark
Old 10-15-2006, 05:20 PM
