480 HP/ 476 ft-lbs on CIS @ .96 bar!
408 RWHP / 405 RTQ (with 15% drivetrain loss)
So finally got the beast dynoed with the RPM switch/solenoid mod that Brian Leask (bleask@cox.net) designed. Check out how flat the AFR curve is now. It's like EFI! WUR Boost enrichment is set at 2.2 bar. I'm going to lower it to 2.1 bar to richen it a bit top end. Right now, it's around 12.5 AFR around 6K. The blue run is before the RPM switch/solenoid mod. The red run is with boost enrichment to trigger at 4400. Notice how much smoother the HP/TQ curve is in mid range. No overich stumbling. I've gained 30 RWHP between 2800-3600! Incredible. Mods: 36mm port K27 1 bar spring (actually getting .96 bar) IA fuel head C2 cams C2 bypass assembly Baileys diverter valve Borla exhaust goingsuperfast.com headers Blownsix Design 965 IC Custom powerflow intake ARP head studs & rod bolts Nology wires Car corner balanced and weighed in at 2750 w/ 1/2 tank of gas
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy Last edited by porschett; 10-23-2006 at 04:54 PM.. |
Crotchety Old Bastard
Fantastic!
Can you go into detail on this RPM Switch mod? Is it more than his custom WUR? What does he charge nowdays for the custom WUR?
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I think Brian has a package deal with the RPM switch/solenoid and custom WUR. You may need to contact him for more details (bleask@cox.net). The switch/solenoid is way cheaper than the custom WUR.
Depending on your setup, you can swap out modules at different RPMs. I had it to trigger the boost enrichment at 4600, but saw the AFR start to go lean. So we made another run with the 4400 module (takes less than 2 sec to swap out) and saw the positive results.
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy |
At 13:1 AFR it appears another rebuild will be in the cards in the not too distant future... That's just too lean for the power being produced. Even 12.5:1 wouldn't be safe as far as I'm concerned.
Matt B '73 911E |
Yep, I realize that. That's why I mentioned that I'm going to increase fuel by lowering the boost enrichment pressure at the WUR.
Congrats David!
Doug
1971 RSR - interpretation |
19 years and 17k posts...
Beautiful car!!! Wow!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Awesome figures! Congrats
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
This is a real-world example of how leaning out the mixture sometimes can provide more power. There are many on Pelican Parts that firmly believe that "richer is better". I presonally don't think you should go much further down than 12.6 while on boost.
AFR curve on display is perfectly OK to me and I don't believe that "At 13:1 AFR it appears another rebuild will be in the cards in the not too distant future". Car has perfect AFR curve where it matters: from 3000 to 5500 RPM. It reaches max power @ 5400 RPM and keeps ~ 12.5 troughout majority of boost part of rev-band. Breathing efficiency falls off over 5500 RPM (probably due to CIS) so I don't think engine is risking detonation even if revved past it's power peak from time to time. Only thing I would do is to richen it a bit after 5200 if possible, otherwise it's OK.
Thank you for your time, |
OK, but what are the EGT's at 12.6 AFR with a 1 bar of boost? 1600F? 1800F? more? Extra fuel is needed to keep temps within acceptable limits. Too much heat can lead to preignition from the exhaust valve getting too hot. The life of the exhaust valves, guides, headers, and turbo are all reduced when temps get too high.
Matt B '73 911E |
Exact or perfect A/F ratios and tuning simply do not matter in a street car, there is a range of values that are acceptable for longevity. You are not on boost long enough for heat to build up. Folks on this board tend to get lost in perfection and miss the big picture. A track car and a street car are soooooooo different in setup that you simply cannot apply the rules of one to another.
Probably the most true statement I've read today. That said- Nice work Porschett! Thanks for sharing vitals. |
I forgot to mention that at dyno time, I was running MS109 and was tuning for max hp and tq.
VP MS109 • Motor Octane: 101 • R+M/2: 105 • Research Octane: 109 With that said, I downloaded my logs from my LM-1. At full boost and 6000 RPM, my AFR never went over 12.6 even though the dyno says it's close to 12:8. I'll err on the save side and go with the dyno's readings. I agree with Rarly8 that it's not a race car and probably won't see anything over 5000 RPM on the streets. I rarely boost anyways. It's just good that the HP's there in case I see a Z06 ;P Normal setup for the car will be .8 bar on 91 octane. So I think the current setup should suffice. Glad beepbeep "approved" of my setup...oh wait...didn't he have to rebuild his motor. LOL
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy Last edited by porschett; 08-24-2006 at 04:07 PM.. |
Me like track days
Any updates?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Still Doin Time
And people think you have to install a V-8 to get that kind of power
With CIS that HP / TQ output is bad-as! You go boy!
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
