Matt-Man's Avatar
Help indentify this switch function on my '73
What is the switch on the dash between the cigarette lighter and the rear window defroster? It is a single position, has a picture of a light and is connected to my low beam circuit. It does not appear to work, so I am curious what it is for?
Thanks, Matt
'73 911 Targa / 2.7 RS spec
Old 10-16-2006, 09:15 AM
pwd72s's Avatar
Ay one time, your car must have had through the horn grill mounted factory fog lights...
Old 10-16-2006, 09:18 AM
Matt,
Sounds to me like the switch for fog lights. If your car does not have them, check to see if there is a wire leading from the switch and ending somewhere under the front bumper.
Larry
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Matt-Man's Avatar
Thanks, my car has the brackets behind the horn grills, so I considered fog lights, but when I hook 12v to the wiring attached to the switch, the low beams come on...
Old 10-16-2006, 09:34 AM
the switch gets power from the low beam circuit. fogs only work on low beam, from the factory anyway.
206 637 4071
Old 10-16-2006, 09:45 AM
pwd72s's Avatar
Sounds like you have all you need but the lights...and the cut down grilles.
Old 10-16-2006, 10:00 AM
Matt-Man's Avatar
Ahh, that make sense! I believe I remember seeing the wiring behind the horn grill, now ALL I need is the lights... so much for the easy part!
Thanks for the help, Matt
Old 10-16-2006, 10:43 AM
Take a close look at pwd72s' picture. You'll also need the special horn grills. They have special openings for the light and bracket to fit through.
Old 10-17-2006, 07:56 AM
Matt-Man's Avatar
Seems like it would be easy to get another set of grills and cut them, but where would I find the lights in an affordable line?
Old 10-17-2006, 09:18 AM
