steering wheel noise
I installed a genuine porsche 930 S steering wheel a while back and it made a scratching noise at lets say under ten mph when you spun it anyway. Then the steering wheel came loose so i replaced the bushing and it was fine. It currently is tight but still makes the sound... anyone know what i should do?
thanks sammy
1976 911S http://imgur.com/aSW9DtX |
The one on my SC does the same thing. I know you were looking for a way to eliminate the noise, but sometimes misery loves company.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Dont know what you mean by that.
do you mean the noise will never go away?
Check the upper bearing on the steering shaft. It is located just below the universal joint that can be accessed in the smuglers hatch. When mine went it got noisy and then the steering was quite difficult to turn.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
my scraping noise comes from the plastic cover rubbing on the wheel adapter
82 SC , 72 914 |
so has anyone fixed it? and how if so
Mine makes the same noise. I've read some where on the forum that this could be scraping on the horn ring. Apply some dielectric (sp) grease to make it go away. I've not tried this yet, maybe this weekend as the wheel needs to come off as well.
2002 Boxster Speed Yellow |
Mine made this scraping noise for awhile right before the upper bearing failed. I did the standard "upper bearing replacement procedure" and everything's fine now.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I second the horn contact. I cleaned mine with a little sandpaper when I put my wheel back on, and it was a little scratchy for a while - went away though.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
I, too, vote for the horn ring contact under the steering wheel. When I sandpapered mine many years ago it resulted in a scraping sound. Polishing it instead of roughing it stopped the noise. Polish the contact button, too.
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
My steering wheel made the same noise...Horn contact ring
86 911 Targa |
