Heat Exchangers in an 80 SC?
The heat exchangers on my 1980 SC are pretty much shot. The pipes themselves are intact, but the shielding is rusted apart. As far as I can tell, there is no cat on the car--the existing exchangers empty directly into the muffler.
Obviously, I need to repair these, and want to keep expenses down. I know that I could do SSI exchangers, but am tempted to buy used OEM ones because they are far less expensive. What year exchangers will fit? Am I correct in assuming that '80 thru '83 ones will? Thanks!
Old 10-17-2006, 05:17 AM
I have a set in my garage from my 81. They are in good shape, I went to the SSIs. Located in the South Florida area
Eric
1981 911 SC 7 & 9 Fuchs, monoballs, 22/27 t-bars, 19/22 swaybars, M&K dual in/ dual out
Old 10-17-2006, 05:26 AM
Eric, I just PM'ed you.
1979 cashmere beige 911SC Coupe
1980 911SC Targa (sold)
1982 911SC Coupe (sold)
1966 912 Coupe (sold)
1975 914 1.8 Plaid Seats (sold)
Old 10-17-2006, 05:32 AM
Less brakes, more gas!
euro911sc's Avatar
I also have an extra set. On my way to just headers...
But, its my second set. The first set I just made some 'OEM' headers by cutting off the heat exchanger tin. Took about 2 hours with the engine in the car using a cutoff wheel and some sheet metal shears. Dropped the engine temps by a noticable amount. My seat of the pants power meter didn't change.
I was in Somerville, MA, at the time and had driven deep into the fall. One day it snowed I didn't really mind the lack of heat, but it would have been nice to have a defroster! 911s really go in the snow... just dont try and turn!
If you can't find any near you or for cheap let me know. I'm also down here in FL.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-17-2006, 05:51 AM
Just to check with the collective wisdom of the board--I haven't found a source to tell me whether exchangers from other years will work on my '80 USA model SC. Will 80-83 work? Thanks
Old 10-17-2006, 11:40 AM
H.E. from other years....
Snowtire,
The 3-liter engines could use H.E. from other year SC models. But the '83 SC in particular uses thicker exhaust flanges but similar bolt pattern. So if you have thinner exhaust flanges in your old HE, your exhaust studs would be too short to bolt in the later HE's unless you install longer exhaust studs. Good luck.....
TD
Old 10-17-2006, 01:25 PM
