thinkfloyd14's Avatar
Send a message via AIM to thinkfloyd14
steering wheel noise
I installed a genuine porsche 930 S steering wheel a while back and it made a scratching noise at lets say under ten mph when you spun it anyway. Then the steering wheel came loose so i replaced the bushing and it was fine. It currently is tight but still makes the sound... anyone know what i should do?
thanks
sammy
1976 911S
http://imgur.com/aSW9DtX
Old 10-16-2006, 05:07 PM
fred cook's Avatar
Cool Ditto......
The one on my SC does the same thing. I know you were looking for a way to eliminate the noise, but sometimes misery loves company.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 10-16-2006, 05:38 PM
Dont know what you mean by that.
do you mean the noise will never go away?
1976 911S
Old 10-16-2006, 06:34 PM
Rouxzy's Avatar
Check the upper bearing on the steering shaft. It is located just below the universal joint that can be accessed in the smuglers hatch. When mine went it got noisy and then the steering was quite difficult to turn.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 10-16-2006, 06:38 PM
my scraping noise comes from the plastic cover rubbing on the wheel adapter
Old 10-16-2006, 06:40 PM
so has anyone fixed it? and how if so
1976 911S
Old 10-16-2006, 07:21 PM
jtfreels's Avatar
Mine makes the same noise. I've read some where on the forum that this could be scraping on the horn ring. Apply some dielectric (sp) grease to make it go away. I've not tried this yet, maybe this weekend as the wheel needs to come off as well.
2002 Boxster Speed Yellow
Old 10-17-2006, 06:34 AM
IROC's Avatar
Mine made this scraping noise for awhile right before the upper bearing failed. I did the standard "upper bearing replacement procedure" and everything's fine now.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-17-2006, 07:08 AM
na2ub's Avatar
I second the horn contact. I cleaned mine with a little sandpaper when I put my wheel back on, and it was a little scratchy for a while - went away though.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 10-17-2006, 07:12 AM
I, too, vote for the horn ring contact under the steering wheel. When I sandpapered mine many years ago it resulted in a scraping sound. Polishing it instead of roughing it stopped the noise. Polish the contact button, too.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 10-17-2006, 07:33 AM
My steering wheel made the same noise...Horn contact ring
86 911 Targa
Old 10-17-2006, 04:23 PM
